Results 1 to 2 of 2
    Kevin Rutledge's Avatar
    Kevin Rutledge Guest
    Default ground and neutral on same screw in main panel
    Hi everyone, just needed some confirmation on this. On the main feed coming in to the main panel they have the ground and neutral on the same screw. I'm pretty new, but it didn't look right to me. thanks for all the input ahead of time. I really do appreciate you guys.
    Default Re: ground and neutral on same screw in main panel
    Quote Originally Posted by Kevin Rutledge View Post
    The neutral is not allowed in any terminal with any other conductor, not even another neutral.
