Thread: Flooring jacks
10-07-2009, 06:22 PM #1
Flooring jacks
Inspected a crawl space where two floor jacks were being used to support the beam above. They were resting on concrete pads but were not embedded in the concrete nor fastened to it in any way. Is this ok or should they be embedded in the concrete?
10-07-2009, 07:17 PM #2
Re: Flooring jacks
Temporary screw jacks are just what they are listed as. Recommend solid supports.
They are however very good, temporarily!!
10-07-2009, 07:27 PM #3
Re: Flooring jacks
10-07-2009, 07:31 PM #4
Re: Flooring jacks
It would probably need a se to determine if these are actually needed or just additional support. I have these supports in my basement and they are doing just fine.
10-08-2009, 05:39 AM #5
Re: Flooring jacks
10-08-2009, 07:10 AM #6
Re: Flooring jacks
I find those on I would say about 15%-20% of the homes I inspect. As others have said they are a temporary house jack. Many times they are used to stiffen or take the vibration out of the floor in a certain area of the home. They are really not adding structural support when used like that.
I don't have a problem with them when they are used to stiffen a section of the floor. But if they are used to support a joist or beam then they need to be replaced with a more permanent support.
10-08-2009, 07:59 AM #7
Re: Flooring jacks
Hello Everyone, this is my first time posting
Besides the Temporary screw jacks shouldn't there also be some kind of vapor barrier layed over the grading? ALM
10-08-2009, 05:59 PM #8
