Results 1 to 12 of 12
Thread: I-Joist Spacing
    Jun 2008
    Default I-Joist Spacing
    I'm seeing I-joists spaced at 19" on center. Whats with that? Why not the normal 12, 16 or 24"?
    Byron Brubaker's Avatar
    Byron Brubaker Guest
    Talking Re: I-Joist Spacing
    Dyslexic Builder????
    Jun 2008
    Default Re: I-Joist Spacing
    Quote Originally Posted by James Risley View Post
    I-joists can be sized for 19.2" centers. This allows one less joist in 8 foot and can still use regular 8 foot plywood/osb. Note that there will be no joist at 48" so the stagger will occur at say 38.4 inches. Look at your measuring tape some but not all have a black diamond on the tape at 19.2", 38.4", etc. This is to aid the framer.
    JR
    I stand edumacated. Just checked my tape. At 19.2 theres a little black diamond. I never had seen it before now. Thanks.
    chris mcintyre's Avatar
    chris mcintyre Guest
    JR
    What James said, plus: We often use roof trusses set at 19.2, it takes the wavy look out of the roof when the sun is at the right angle and you don't have to use clips for the sheathing.
    I have never seen floor joist at 19.2" or 24" oc. but I-joist like trusses (roof or floor) are designed by an engineer, so if installed per drawings will meet code. I think that I-joist are a great solution for second story floor systems that span over large first story rooms, sure beats the I-beams and flitch plates we had to use. I-joist, especially longer spans, do have some deflection, so while the 19.2" may be acceptable IMO it is not the best way to keep the dishes from rattling in the china cabinet when you walk across the room.
    Phil Brody's Avatar
    Phil Brody Guest
    It's all based on design and load 12",16, 19.2, 24, all work if designed properly, sometimes getting the insulation to cooperate is another thing.
    Milton Grew's Avatar
    Milton Grew Guest
    We have used 19.2" spacing for floor trusses. It's a little more efficient and can save some costs on a large building.
    Aug 2009
    Michigan
    I have done 19.2 centers a few times... designers idea not mine. I didn't really care for it. Really doesn't save much time or material. Just a hassle getting 16" wall studs to stack.
    Randy Gordon, construction
    May 2010
    St. George, UT
    As an insulation contractor, I hate this..."special order" for fiberglass batts and correct size lightning rods (supports)....so the framing contractor can save a joist or two....and use the little black diamond on their tape measure
    Dec 2009
    Florida
    Quote Originally Posted by Larry Morrison View Post
    Just curious, is the overall cost of furnishing and installing "special order" (19") insulation actually more or less than standard insulation (16")?
    May 2010
    St. George, UT
    Where we are it is just a few cents more but the real pain is a contractor that awards you the job and then wants it done tomorrow because he has scheduled drywallers the day after tomorrow...In larger cities 19.2 inch batts probably aren't that big a deal to get. If it is a small job, many times we have used 23" batts and "made them work".
    We mainly do blown cellulose both walls and ceiling/attic (because fiberglass is crapola-- IMO) we don't stock fiberglass as a rule.
    With construction being as slow as it is now many places aren't even stocking a good supply of standard size and R-value batts. So that also comes into play.
    Everyone needs to have this I-Joist pocket guide on their computer or wherever. It is for Weyerhaeuser joist but all brands have similar requirements. I could not upload the file due to the size but this is the link to the document.
    http://www.ilevel.com/literature/TJ-9001.pdf
    Fuquay Varina, NC
    Ditto on what Scott said. Look around on job sites. They are left laying around all the time.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
