    Default white roof new to me
    I have never seen this kind of roofing material before. It looks like rubber with a white reflective film of some kind. Can anyone enlighten me?
    Default Re: white roof new to me
    Looks like TPO. I have not seen peeling like that before.
    Mike Lamb
    Inspection Connection, Inc.
    It looks like a heat-welded SBS modified bitumen membrane with a 'cool' laminate synthetic film.
    http://www.soprema.us/data/sites/38/...arBrochure.pdf
    _____________________________
    Don Putnam
    Austin, Texas
    www.roofconsulting.com
    Aug 2011
    I note that a similar thread is "Where white man went wrong".
    I didn't check that thread, (because it's probably too depressing), but it could be the longest thread in this forum.
    Jul 2010
    Wisconsin
    Kind of looks like the peel and stick roofing at Menards: Reflective White Aluminum Faced Peel & Stick Roofing at Menards Buddy removed a bunch of this stuff off a flat roof as it started to leak after a few years, your photo looks kind of like what he removed.
    Lansdale, PA
    Quote Originally Posted by Mike Lamb View Post
    It is not TPO. TPO is solid white and is heat sealed. You would not see black at the joints.
    This is a torch-applied modified bitumen membrane. The modified bitumen is protected by an aluminum foil cladding, which is made white by adding a synthetic laminate. The peeling shown in the second photo is the result of over-heating the edge of the sheet, melting the aluminum cladding. This is repairable. This type of roof has an approximate 25+ year life expectancy.
    Don Putnam
    Austin, Texas
