Thread: Securing pedestal sink
12-10-2014, 04:08 PM #1
12-10-2014, 04:28 PM #2
Re: Securing pedestal sink
I don't see it as a problem.
12-10-2014, 05:27 PM #3
What did you say about that old door backsplash?
12-10-2014, 05:33 PM #4
12-10-2014, 06:11 PM #5
Somehow someway it needs to be secured so that the stand and bowl can not move. Movement will cause leaks!
12-18-2014, 08:22 AM #6
12-18-2014, 08:35 AM #7
They can drill holes and screw it to the floor. Or super glue.
One of my expressions is 'be creative and fix it'.
If the sink bowl has no overflow built in, 'remove the stopper to avoid the chance of flooding'.
12-18-2014, 10:27 AM #8
Is that light coming through the lower left side of the door? I sure hope the door doesn't still open.
12-22-2014, 06:25 AM #9
I dislike the flexible drain connections I see from time to time but this actually looks like a place one might make sense if there was no way to secure it properly.
Of course, as a home inspector, all we have to say it that it isn't properly secured and recommend that it be properly secured.
My thought would be something like a pair of wrought iron shelf brackets that could be attached to the wall and clamped or welded to the sink support to help prevent it from moving and dislodging the DWV connection.
12-22-2014, 09:52 AM #10
I like the door, very cool. I don't believe there is a flexable drain, it looks like a black cover to hide the pipes, similar to fabric sleeves people put on hanging light fixtures.
I probably wouldn't worry about it unless it was in earthquake country, then I would make some kind of attachment to the door.
Agreed with no overflow: the stopper can be replaced with a decorative cover that has openings.
